WIC-2T compatibility between router 2800 and 1941 series
imran.edzereiq
Hi all,
My current routers are the 2811 with WIC-2T. As this is an old router, we plan to purchase the 1941 series for our academy.
To save cost. we plan to reuse the existing WIC-2T by installing in the 1941 series.
My question is, is it possible to do that in terms of compatibility?
Thank you
Leo Laohoo
WIC-1T/2T is not supported.  If you insert the card in the router/IOS will disable the the module (EoS).  You will need to upgrade to HWIC-2T.
Leo Laohoo
