215
Participant
WIC2T and MLLN
hi,
When i connect 1700 WIC2t to my MLLN circuit, the circuit is comming up on hdlc and pp as well.
But when i budle it with multilink (PP multilink group) it's going down.
Configuration is fine and very less at both ends.
the circuit is BSNL MLLN.
in the same E1 multiple customer routers are working fine with same config.
I have seen some posts and found WIC 2t having issues with MLLN.
any guidance will be helpfule.
Hall of Fame Master
Re: WIC2T and MLLN
You are trying multilink on a single circuit? What's for ?
Participant
Re: WIC2T and MLLN
im using crypto tunnels and voice traffic , which are well supported by multilink interface at both sides.
Participant
Re: WIC2T and MLLN
any insputs?
Ask the Expert- Webex Hybrid Services Solutions
