Community Helping Community
107
Beginner
Will a 3845 router be able to operate effectively with 4 T3 modules?
This would be a temporary solution for about a week. The router will only serve as a pass through to the core site, no internal LAN routing.
3 REPLIES 3
Re: Will a 3845 router be able to operate effectively with 4 T3
The following documentation states that a maximum of 2 NM-1T3 are supported in a 3845.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Beginner
Yes, I know that 2 are supported as stated in the documentation. But can it function temporarily with 4? I've seen a 3725 fucnction for a long time with 2 T3 modules and the documentation says it only supports 1.
According to the following Miercom report, the 3845 can handle up to 1.1Gbps of aggregated traffic. So from a sheer horse power viewpoint, this should be plenty to support 4 T3. Try getting the 4 NM-1T3 in the chassis and see if it sees them correctly.
http://www.miercom.com/dl.html?fid=20040901&type=report
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Content for Community-Ad
FusionCharts will render here
