02-05-2013 03:51 AM - edited 03-04-2019 06:56 PM
Hi all,
Got a question since I won't be able to test on lab,
Will configuring OSPF NSF cause an outage / adjacency lost to the OSPF neighbor
many thanks in advance.
02-05-2013 04:30 AM
Michael,
NSF should be enabled by default. Look at "show ip ospf inter" and you should see below:
R3#sh ip ospf inter
FastEthernet0/0 is up, line protocol is up
<<< Output omitted >>>
Cisco NSF helper support disabled
IETF NSF helper support enabled
Index 1/1, flood queue length 0
I had to specifically disable above (Cisco NSF helper). Reenabling:
R3(config-router)#nsf cisco helper dis
R3(config-router)#no nsf cisco helper disable
R3(config-router)#do sh ip ospf inter | inc FastEth|NSF
Cisco NSF helper support enabled
The adjacencies didn't come down. You also may want to refer to this article under "Disabling NSF Awareness." It also states that it's enabled by default.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftosnsfa.html
HTH,
John
*** Please rate all useful posts ***
02-05-2013 04:42 AM
Thanks John,
Indeed it should be per default enabled, but I think someone disabled it for some reason or by mistake.
Many thanks for testing and your answer, it really answered my question.
kind regards,
Michael
