Join Customer Connection to register!
406
tlxbx
Beginner
wired and wireless Vlan pointing to 1 GLBP? Help!
Wired end device in pic are Access points(AP)
Configured wired ports to wired VLAN 50.
Configured AP ports to wireless VLAN 60.
MDF switch has a static route of a gateway of last resort pointing to GLBP IP.
AP has picked up IP address from its scope (10.2.26.0/24) and i see several wireless users has already got correct IP aswell in DHCP server.
My main question is.....
Since WAN LAN IP and Wired VLAN are in the same scope....do i need to create another virtual interface and configure GLBP in WAN routers for the wireless VLAN ? or this setup will work as well?
Also how did AP & wireless users got correct IP from their scope since WAN LAN IP is the same scope as wired VLAN & there is no WAN LAN IP with wireless vlan scope.  I thought i need another LAN port in WAN with same scope as wireless VLAN for this to work.
Please help..I am confused...
0 REPLIES 0
