115
Highlighted
Beginner
wireless cisco 877w
Guys,
I am having issues having the wireless working on cisco 877w. Could someone please enlighten me on what went wrong?
Please find attached config
version 12.4
no service pad
service password-encryption
hostname IDIOT
boot-start-marker
boot system flash c870-advipservicesk9-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
logging buffered 4096
enable secret 5 $1$CK1Y$ABuBRRdGJGzBBBdVcOBVd.
aaa new-model
aaa authentication login local_auth local
aaa session-id common
clock timezone SGT 8
dot11 syslog
dot11 ssid SINGTEL-IDIOT
 vlan 1
 authentication open
 authentication key-management wpa
 guest-mode
 wpa-psk ascii 7 105D030C5C444B5909
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.254
ip dhcp pool HOME-DHCP
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   dns-server 8.8.8.8
ip cef
no ip bootp server
ip name-server 8.8.8.8
no ipv6 cef
username alex password 7 105D030C5C444B5909
archive
 log config
  hidekeys
ip ssh version 2
bridge irb
interface ATM0
 no ip address
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 description $ES_WAN$$FW_OUTSIDE$
 ip flow ingress
 pvc 0/100
  encapsulation aal5snap
  protocol ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid SINGTEL-IDIOT
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 world-mode dot11d country SG outdoor
 no cdp enable
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 ip virtual-reassembly
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 bridge-group 1
interface Dialer0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp authentication pap callin
 ppp pap sent-username bluefrog@singnet password 7 030C08015F05325E4C
interface BVI1
 ip address 192.168.1.254 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 05180C1A781F175B1C
 login authentication local_auth
 transport input telnet ssh
scheduler max-task-time 5000
ntp source ATM0.1
ntp server 103.4.109.106
end
1 REPLY 1
Highlighted
Beginner
What are the issues?
What is expected?
cheers,
Vasco
Cheers,
Vasco
