11-14-2018 02:17 AM - edited 03-05-2019 11:03 AM
I'm having a Cisco 2500 Series Wireless Controller and it keep dropping all the AP's, what could be the problem and i have attached pic of wlc.
Any assistance would be really appreciated.
Solved! Go to Solution.
11-14-2018 04:20 AM
without knowing any details (what do your logs show ?), try and upgrade to release 8.0.152.0 MD...
11-15-2018 02:54 AM
I would suggest you to upgrade WLC software to some version 8.x. There are numerous bugs in the 7.x version.
Try to upgrade and let me know.
Cheers,
Milos
11-14-2018 04:20 AM
11-14-2018 05:17 AM
Coverage hole pre alarm for client[1] a0:ed:cd:5b:af:18 on 802.11b/g interface of AP 1c:1d:86:52:52:f0 (APW21-W21-2F-STAIRS). Hist: 2 0 2 0 0 0 6 21 111 221 209 137 4 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Rogue AP: 4c:5e:0c:28:cf:d7 detected on Base Radio MAC: d0:c7:89:33:ea:80 Interface no: 1(802.11a) Channel: 52 RSSI: -84 SNR: 8 Classification: unclassified, State: Alert, RuleClassified : N, Severity Score: 0, RuleName: N.A. ,Classified AP MAC: 00:00:00:00:00:00 ,Classified RSSI: 0
Rogue AP: 66:70:33:dd:ad:07 detected on Base Radio MAC: d0:c7:89:33:ea:80 Interface no: 0(802.11n(2.4 GHz)) Channel: 1 RSSI: -71 SNR: 16 Classification: unclassified, State: Alert, RuleClassified : N, Severity Score: 0, RuleName: N.A. ,Classified AP MAC: 00:00:00:00:00:00 ,Classified RSSI: 0
Coverage hole pre alarm for client[1] 8c:9f:3b:9e:16:9f on 802.11b/g interface of AP 1c:1d:86:52:52:f0 (APW21-W21-2F-STAIRS). Hist: 1 0 0 0 0 2 21 14 17 20 34 12 2 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
11-14-2018 06:22 AM - edited 11-14-2018 06:25 AM
Hello
How many APs are connected to the wlc?
Do they all drop at once of sporadically?
Are the Aps receiving the correct power from there POE switches?
sh msglog
sh eventlog
sh traplog
Note: if you upgrade the wlc then the APs will also get upgraded and reload so if you have alot of them you can cause some outage if you dont plan the upgrade.
11-14-2018 07:20 AM
I have 14 Access point connected
They all drop at once.
I'm not really sure about the correct power but a month ago everything its been working just fine, all of a sudden the AP'S started dropping.
sh msglog
Message Log Severity Level ...................... ERROR
*apfOrphanSocketTask: Nov 14 16:12:29.376: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:12:28.989: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:12:19.525: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:12:19.485: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:51.845: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:51.029: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:28.381: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:27.623: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:24.826: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:13.845: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:05.610: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
*apfOrphanSocketTask: Nov 14 16:11:04.382: #IPV6-3-INVALID_ADDR_ORPHAN: ipv6_net.c:715 Invalid ipv6 address ::, failed to do data gleaning.
sh eventlog
(Cisco Controller) >show eventlog
Time
File Line TaskID Code d h m s
EVENT> bootos.c 1544 144A3750 AAAAAAAA 0 0 0 17
EVENT> bootos.c 1544 144A3750 AAAAAAAA 0 0 0 18
EVENT> bootos.c 1544 144A3750 AAAAAAAA 0 0 0 35
CORRUPT ENTRY >>>>>>>00000000 00000000 00000000 000004FA 00000081 00000000
CORRUPT ENTRY >>>>>>>00000000 00000000 00000000 00000000 00000000 00000000
CORRUPT ENTRY >>>>>>>00000000 00000000 00000000 2D2C29B0 00000000 00000000
CORRUPT ENTRY >>>>>>>00000000 2D2C2938 00000000 00000000 00000000 00000000
sh traplog
(Cisco Controller) >show traplog
Number of Traps Since Last Reset ............ 2687
Number of Traps Since Log Last Displayed .... 12
Log System Time Trap
0 Wed Nov 14 16:18:52 2018 Coverage hole pre alarm for client[1] ac:36:13:eb
:23:c4 on 802.11b/g interface of AP 1c:1d:86:52:5
2:f0 (APW21-W21-2F-STAIRS). Hist: 3 1 3 5 11 11 1
5 25 20 35 51 34 19 11 8 3 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0
1 Wed Nov 14 16:18:52 2018 Coverage hole pre alarm for client[1] 04:1b:ba:df
:39:b2 on 802.11b/g interface of AP 1c:1d:86:52:5
2:f0 (APW21-W21-2F-STAIRS). Hist: 1 0 1 1 0 1 2 1
0 11 17 9 7 1 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
2 Wed Nov 14 16:18:52 2018 Coverage hole pre alarm for client[1] a0:ed:cd:5b
2:f0 (APW21-W21-2F-STAIRS). Hist: 0 0 2 1 1 1 0 1
8 144 87 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
--- ------------------------ -------------------------------------------------16:20:13 2018 Rogue AP : f2:9f:c2:95:3a:ea removed from Base R
adio MAC : f8:4f:57:78:68:00 Interface no:0(802.1
1b/g)
16:20:13 2018 Rogue AP : 34:12:98:08:be:44 removed from Base R
adio MAC : c0:7b:bc:cf:15:a0 Interface no:0(802.1
1n(2.4 GHz))
adio MAC : 1c:1d:86:52:56:a0 Interface no:0(802.1
1n(2.4 GHz))
adio MAC : d0:c7:89:33:ea:80 Interface no:0(802.1
1n(2.4 GHz))
1n(2.4 GHz))
11-14-2018 08:14 AM
how do you have rogue AP management configured ? Post the full config of the 2504...
11-14-2018 08:47 AM - edited 11-14-2018 08:56 AM
Hello
what version code are you running?
would you know in that past month of any changes been made on your network?
is it possible you might have a duplicate ip conflict with the mgt wlc ip or a network issue that drops the connection towards the wlc?
Can you post if applicable the output of the following:
debug lwapp events enable
11-15-2018 02:54 AM
Cheers,
Milos
11-16-2018 02:12 AM
