WPA2 Enterprise problem
andrew005
I have some problems with WPA2 Enterprise setup. I configured profiles through advanced setup, the connection did not appear. I am asking for help and a little explanation on how to fix the problem.
@andrew005
 You need to make sure the router and the Radius server is communicating. In your case it was not. The server did not have an IP address and the cable is cross-over, it should be straightforward
You can look the file I am attaching.
@andrew005
Thank you! It was very helpful.
