x.25 problem
xhackuss1
I have in my network three routers that have this setup. R1<--->R2<--->R3. Connection between R1 and R2 is serial whilst that between R2 and R3 is ethernet.I have an X25 client connected to R1 as ^104 and from R1 and R2,the client is reachable when I do "pad 104".However,when I try to access thesame client from R3 using "pad 104",I get the message " % Connection refused by remote host"
Can anybody tell me what needs to be done in order to get R3 access the X25 client coonected to R1.
paolo bevilacqua
Hi, you would need to X.25 over ethernet or X.25 over IP (XOT) to do pad natively from R3. Since it kind of awkward to do this, perhaps you are better configuring protocol translation (either 1 or 2 steps method) so that telnet from R3 would become pad on r1.
thanks a lot for responding to my problem.
Could you please have a look at my configs and make suggestions. Also,could you possibly show me how to configure the protocol translation as you suggested.
For R1
int serial1/0:0
ip address 10.3.x.206 255.255.255.252
interface Serial0/2
ip address 10.3.x.141 255.255.255.252
encapsulation x25 dce
no ip route-cache
no ip mroute-cache
x25 address 104
x25 htc 32
x25 ips 256
x25 ops 256
clockrate 64000
lapb T1 2000
lapb N2 10
x25 route ^104 interface Serial0/2
x25 route ^900 xot 10.3.w.39 10.3.w.71
R1# sh cdp nei det
Entry address(es):
IP address: 10.3.x.205
Interface: Serial1/0:0, Port ID (outgoing port): Serial1/0:0
For R2
int s1/0:0
ip address 10.3.x.205 255.255.255.252
x25 route ^900 xot 10.x.y.2
x25 route ^104 xot 10.3.x.141 10.3.x.109
R2#sh cdp nei det
Entry address(es):
IP address: 10.3.x.206
Entry address(es):
IP address: 10.3.w.73
Interface: FastEthernet0/1, Port ID (outgoing port): FastEthernet0/1
For R3
int fa0/1
ip address 10.3.w.73 255.255.255.224
R3#sh cdp nei det
Entry address(es):
IP address: 10.3.w.71
x25 route ^104 xot 10.3.w.71 10.3.w.39
you only can check you config, based of it works or not. However I do not quite understand the x25 routes on R3.
Your guide to PT:
http://cisco.com/en/US/docs/ios/12_2/termserv/configuration/guide/tcfpt_ps1835_TSD_Products_Configuration_Guide_Chapter.html
Good luck!
