x.y.z.0 ip address
hs08
If i have subnet 10.10.10.0/23 this mean :
  • Network Addr is 10.10.10.0
  • Broadcast Addr is 10.10.11.255
  • Usable IP range from 10.10.10.1 - 10.10.11.254
My question is IP 10.10.11.0 is valid address?
since 10.10.11.0 is not network and not broadcast of 10.10.10.0/23 then you can use it
MHM
6 Replies 6
MHM
Thanks for your confirmation. But are you ever use .0 as host ip address?
sure the mask /23 allow you to use .0
MHM
Leo Laohoo
Command:  ip subnet-zero
yes....
Kind Regards
Paul
Joseph W. Doherty
"My question is IP 10.10.11.0 is valid address?"
As 10.10.11.0/23, as others have already noted, yes it is a valid "normal" IP address.
To be clear, it's easy to believe x.x.x.0 is "special", because of historic class C network address block allocations, but the real issue is the first IP within a network is also used as network address, which is confusing, but actually doesn't preclude using an IP like 10.10.11.0/24 as a host IP, but also historically, sometimes the first network IP was used as a network broadcast IP.  So, we generally exclude using the first network block IP, the network address, except in the case of using a /31 or /32.
