x25 facility throughput problem
edaguet
Hi all,
We meet a big problem. We have two 3640 routers with one 4 ports async/sync serial port configured with Snasw/Ipsec image. When we configure serial interface with x25 facility throughput with a 64000 rate throughput, we met an error:
1/in version 12.3(14)T5,
bry1rtrbusx2501#
rtr1busx2501(config-if)#x25 facility throughput ?
<75-48000> Input throughput bit rate
2/with version 12.4(5)
rtr2busx2501(config-if)#x25 facility throughput ?
but in 12.3T version should support 64000 x25 throughput facility ( CITTT 1988). See http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f5a.html#wp1054749
Any ideas?
Georg Pauwen
can you try and configure the command ´bandwidth 64´ on your interface and check if it lets you enter 64000 then ?
GP
Same thing.
