x25 over TCP/IP
fgasimzade
Level 4
Level 4
I am trying to configure X25 over TCP.
Serial interface conf:
interface Serial0/0
no ip address
encapsulation x25 dce
no ip mroute-cache
x25 address *******
In the routing table i have the following entry:
x25 route .* xot <IP Adress>
The remote hosts Ip address is reachable, but when I'm trying sh x25 vc nothing comes up.
I am new to x25, can anyone tell me what is wrong with my conf
Thank you in advance
8 Replies 8
andrew.prince
Level 10
Level 10
I checked it before. The serial interface is up, and the protocol is up, but sh x25 vc still shows me nothing. In fact, it showed me x25 details only first time I typed in the command.
Have you performed the trouble shooting/debugging at the bottom of the config example?
Yes, I have done it, debugging and sh x25 vc returns me nothing
No output at all?? I would proably try a re-load!
The issue is solved, thank you
np - not sure I hepled!
I forgot to set up clockrate on the interface ))
