XOT Redundancy Timers
In the command
x25 route nri1 xot ip1 ip2
It tries the XOT connection to ip1 for 30 seconds and fails and then tries to ip2.
How can I do to change the 30 seconds period?.
smahbub
Level 6
Level 6
By default the XOT connection is kept alive for 60 seconds and also based on keepalive retry count set.For changing this time the following commands can be used:
1)xot-keepalive-period seconds
seconds-the number of seconds for keepalives between Xot connections.60 seconds is default
2)xot-keepalive-tries count
count-represents the number of times the keepalive message should be sentt before dropping the connection.By default it is 4 times.
For more information about XOT timer configuration with examples refer the following URL:
http://www.cisco.com/en/US/docs/ios/12_3/wan/command/reference/wan_x1g.html#wp1033412
