Dear all,
If an X25 route is configured on a router with an xot-source using an interface that has no IP address assigned, will the router by default use the wan interface? This is what is happening on routers running 12.0(11)ip plus.
已解决! 转到解答。
with XOT, as like with other things, in lack of a source specified, router should use the interface used for outgoing to destination. Even if unnumbered, it should have an address.
Thank you for the nice rating and good luck with your project!
