XR DEVICE ISSUES
pramod
Hi all,
How to erase startup config on CRS device running XR version? Write erase command is not there...How to erase all my running / start up configs to make it as a fresh box.Please help me....
Laurent Aubert
There is not concept of running and startup config in XR.
To erase all your configuration, use the commit replace command without any configuration entered. It means you replace your configuration by an empty one
Laurent.
