ZBF - Port Forwarding
NathanLKoch
I can't seem to get zbf and port forwarding working.
Current configuration : 15831 bytes
! Last configuration change at 10:07:40 UTC Sun Feb 9 2020 by nkoch
! NVRAM config last updated at 04:38:27 UTC Tue Feb 4 2020 by nkoch
version 15.7
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service sequence-numbers
hostname NASA
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging console critical
enable secret 5
enable password 7
aaa new-model
aaa authentication login local_auth local
aaa session-id common
vlan ifdescr detail
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.20.1 192.168.20.60
ip dhcp excluded-address 192.168.30.1 192.168.30.60
ip dhcp excluded-address 192.168.40.1 192.168.40.60
ip dhcp excluded-address 192.168.50.1 192.168.50.60
ip dhcp excluded-address 192.168.60.1 192.168.60.60
ip dhcp excluded-address 192.168.70.1 192.168.70.60
ip dhcp excluded-address 192.168.80.1 192.168.80.60
ip dhcp pool vlan 20
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
 dns-server 208.67.222.222 208.67.220.220
ip dhcp pool vlan 30
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
ip dhcp pool vlan 40
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
ip dhcp pool vlan 50
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
ip dhcp pool vlan 60
 network 192.168.60.0 255.255.255.0
 default-router 192.168.60.1
ip dhcp pool vlan 70
 network 192.168.70.0 255.255.255.0
 default-router 192.168.70.1
ip dhcp pool vlan 80
 network 192.168.80.0 255.255.255.0
 default-router 192.168.80.1
no ip bootp server
ip host JPL 192.168.2.2
ip host GOLDSTONE 192.168.2.6
ip name-server 216.218.130.2
ip name-server 216.218.131.2
ip name-server 216.218.132.2
ip inspect WAAS flush-timeout 10
ip ddns update method update
 HTTP
  add https://@ipv4.tunnelbroker.net/nic/update?hostname=
 interval maximum 0 0 5 0
ip cef
login block-for 13500 attempts 35 within 13500
ipv6 unicast-routing
ipv6 dhcp pool vlan
ipv6 dhcp pool vlan20
 address prefix 2001:470:1F19:AB:2000::/68
 dns-server 2620:119:35::35
 dns-server 2620:119:53::53
ipv6 cef
license udi pid CISCO2911/K9 sn FGL1741129H
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package datak9
vtp mode transparent
username nkoch password 7
redundancy
 notification-timer 120000
no cdp run
class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
 match access-group name INSIDE-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-INSIDE-CLASS
 match access-group name OUTSIDE-TO-INSIDE
class-map type inspect match-all V80-TO-OUTSIDE-CLASS
 match access-group name V80-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V80-CLASS
 match access-group name OUTSIDE-TO-V80
class-map type inspect match-all V30-TO-OUTSIDE-CLASS
 match access-group name V30-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V30-CLASS
 match access-group name OUTSIDE-TO-V30
class-map type inspect match-all V20-TO-OUTSIDE-CLASS
 match access-group name V20-TO-OUTSIDE
 match access-group name ip620-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V20-CLASS
 match access-group name OUTSIDE-TO-V20
 match access-group name OUTSIDE-TO-ip620
class-map type inspect match-all V70-TO-OUTSIDE-CLASS
 match access-group name V70-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V70-CLASS
 match access-group name OUTSIDE-TO-V70
class-map type inspect match-all V60-TO-OUTSIDE-CLASS
 match access-group name V60-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V60-CLASS
 match access-group name OUTSIDE-TO-V60
class-map type inspect match-all V50-TO-OUTSIDE-CLASS
 match access-group name V50-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V50-CLASS
 match access-group name OUTSIDE-TO-V50
class-map type inspect match-all V40-TO-OUTSIDE-CLASS
 match access-group name V40-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-V40-CLASS
 match access-group name OUTSIDE-TO-V40
policy-map type inspect V60-TO-OUTSIDE-POLICY
 class type inspect V60-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect V40-TO-OUTSIDE-POLICY
 class type inspect V40-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-V60-POLICY
 class type inspect OUTSIDE-TO-V60-CLASS
  drop
 class class-default
  drop
policy-map type inspect V20-TO-OUTSIDE-POLICY
 class type inspect V20-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect V70-TO-OUTSIDE-POLICY
 class type inspect V70-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-V40-POLICY
 class type inspect OUTSIDE-TO-V40-CLASS
  drop
 class class-default
  drop
policy-map type inspect V30-TO-OUTSIDE-POLICY
 class type inspect V30-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-V80-POLICY
 class type inspect OUTSIDE-TO-V80-CLASS
  drop
 class class-default
  drop
policy-map type inspect OUTSIDE-TO-V30-POLICY
 class type inspect OUTSIDE-TO-V30-CLASS
  inspect
 class class-default
  drop log
policy-map type inspect OUTSIDE-TO-V50-POLICY
 class type inspect OUTSIDE-TO-V50-CLASS
  drop
 class class-default
  drop
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
 class type inspect INSIDE-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect V50-TO-OUTSIDE-POLICY
 class type inspect V50-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-V20-POLICY
 class type inspect OUTSIDE-TO-V20-CLASS
  drop
 class class-default
  drop
policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
 class type inspect OUTSIDE-TO-INSIDE-CLASS
  drop
 class class-default
  drop
policy-map type inspect V80-TO-OUTSIDE-POLICY
 class type inspect V80-TO-OUTSIDE-CLASS
  inspect
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-V70-POLICY
 class type inspect OUTSIDE-TO-V70-CLASS
  drop
 class class-default
  drop
zone security INSIDE
zone security OUTSIDE
zone security vlan20
zone security vlan30
zone security vlan40
zone security vlan50
zone security vlan60
zone security vlan70
zone security vlan80
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
 service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
 service-policy type inspect OUTSIDE-TO-INSIDE-POLICY
zone-pair security 20-TO-OUT source vlan20 destination OUTSIDE
 service-policy type inspect V20-TO-OUTSIDE-POLICY
zone-pair security 30-TO-OUT source vlan30 destination OUTSIDE
 service-policy type inspect V30-TO-OUTSIDE-POLICY
zone-pair security 40-TO-OUT source vlan40 destination OUTSIDE
 service-policy type inspect V40-TO-OUTSIDE-POLICY
zone-pair security 50-TO-OUT source vlan50 destination OUTSIDE
 service-policy type inspect V50-TO-OUTSIDE-POLICY
zone-pair security 60-TO-OUT source vlan60 destination OUTSIDE
 service-policy type inspect V60-TO-OUTSIDE-POLICY
zone-pair security 70-TO-OUT source vlan70 destination OUTSIDE
 service-policy type inspect V70-TO-OUTSIDE-POLICY
zone-pair security 80-TO-OUT source vlan80 destination OUTSIDE
 service-policy type inspect V80-TO-OUTSIDE-POLICY
zone-pair security OUT-TO-20 source OUTSIDE destination vlan20
 service-policy type inspect OUTSIDE-TO-V20-POLICY
zone-pair security OUT-TO-30 source OUTSIDE destination vlan30
 service-policy type inspect OUTSIDE-TO-V30-POLICY
zone-pair security OUT-TO-40 source OUTSIDE destination vlan40
 service-policy type inspect OUTSIDE-TO-V40-POLICY
zone-pair security OUT-TO-50 source OUTSIDE destination vlan50
 service-policy type inspect OUTSIDE-TO-V50-POLICY
zone-pair security OUT-TO-60 source OUTSIDE destination vlan60
 service-policy type inspect OUTSIDE-TO-V60-POLICY
zone-pair security OUT-TO-70 source OUTSIDE destination vlan70
 service-policy type inspect OUTSIDE-TO-V70-POLICY
zone-pair security OUT-TO-80 source OUTSIDE destination vlan80
 service-policy type inspect OUTSIDE-TO-V80-POLICY
interface Loopback0
interface Loopback1
 no ip address
interface Tunnel0
 description Hurricane Electric IPv6 Tunnel Broker
 no ip address
 zone-member security OUTSIDE
 ipv6 address
 ipv6 enable
 tunnel source GigabitEthernet0/0
 tunnel mode ipv6ip
 tunnel destination
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 no mop enabled
interface GigabitEthernet0/0
 ip ddns update update
 ip address dhcp hostname NASA
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 zone-member security INSIDE
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip address 192.168.2.1 255.255.255.0
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
 ip nat inside
 zone-member security vlan20
 no cdp enable
 ipv6 enable
 ipv6 nd managed-config-flag
 ipv6 dhcp server vlan20
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
 ip nat inside
 zone-member security vlan30
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 192.168.40.1 255.255.255.0
 ip nat inside
 zone-member security vlan40
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.50
 encapsulation dot1Q 50
 ip address 192.168.50.1 255.255.255.0
 ip nat inside
 zone-member security vlan50
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.60
 encapsulation dot1Q 60
 ip address 192.168.60.1 255.255.255.0
 ip nat inside
 zone-member security vlan60
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.70
 encapsulation dot1Q 70
 ip address 192.168.70.1 255.255.255.0
 ip nat inside
 zone-member security vlan70
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.80
 encapsulation dot1Q 80
 ip address 192.168.80.1 255.255.255.0
 ip nat inside
 zone-member security vlan80
 no cdp enable
 ipv6 enable
interface GigabitEthernet0/1.400
 no cdp enable
interface GigabitEthernet0/2
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 shutdown
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns view default
 domain name vastspace.ca
 domain resolver source-interface GigabitEthernet0/0
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat outside source list 201 interface GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip identd
ip access-list extended INSIDE-TO-OUTSIDE
ip access-list extended OUTSIDE-TO-INSIDE
ip access-list extended OUTSIDE-TO-V20
ip access-list extended OUTSIDE-TO-V30
 permit tcp any host 192.168.30.67 eq www
 permit tcp any host 192.168.30.67 eq 443
ip access-list extended OUTSIDE-TO-V40
ip access-list extended OUTSIDE-TO-V50
ip access-list extended OUTSIDE-TO-V60
ip access-list extended OUTSIDE-TO-V70
ip access-list extended OUTSIDE-TO-V80
ip access-list extended V20-TO-OUTSIDE
 permit ip 192.168.20.0 0.0.0.255 any
ip access-list extended V30-TO-OUTSIDE
 permit ip 192.168.30.0 0.0.0.255 any
ip access-list extended V40-TO-OUTSIDE
 permit ip 192.168.40.0 0.0.0.255 any
ip access-list extended V50-TO-OUTSIDE
 permit ip 192.168.50.0 0.0.0.255 any
ip access-list extended V60-TO-OUTSIDE
ip access-list extended V70-TO-OUTSIDE
ip access-list extended V80-TO-OUTSIDE
 permit ip 192.168.80.0 0.0.0.255 any
logging trap debugging
logging facility local2
dialer-list 1 protocol ip permit
ipv6 route ::/0 Tunnel0
ipv6 ioam timestamp
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 192.168.30.0 0.0.0.255
access-list 1 permit 192.168.40.0 0.0.0.255
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 1 permit 192.168.60.0 0.0.0.255
access-list 1 permit 192.168.70.0 0.0.0.255
access-list 1 permit 192.168.80.0 0.0.0.255
ipv6 access-list OUTSIDE-TO-ip620
 permit icmp any any unreachable
 permit icmp any any packet-too-big
 permit icmp any any hop-limit
 permit icmp any any reassembly-timeout
 permit icmp any any header
 permit icmp any any next-header
 permit icmp any any parameter-option
 permit icmp any any echo-request
 permit icmp any any echo-reply
 permit icmp any any dhaad-request
 permit icmp any any dhaad-reply
 permit icmp any any mpd-solicitation
 permit icmp any any mpd-advertisement
 permit icmp any any nd-na
 permit icmp any any nd-ns
ipv6 access-list ip620-TO-OUTSIDE
 permit ipv6 2001:470:1F19:AB:2000::/68 any
control-plane host
control-plane
 vstack
banner login ^C
*****        ********* *****              ********************  *****              *****     ^C
banner motd ^C
Welcome to ^C
line con 0
 exec-timeout 5 0
 login authentication local_auth
 transport output telnet
 speed 115200
line aux 0
 exec-timeout 15 0
 modem InOut
 transport input telnet
 flowcontrol hardware
line 2
 exec-timeout 15 0
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7
 transport input none
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp update-calendar
ntp server 0.us.pool.ntp.org
end
"Fortune favors the brave."
39 Replies 39
I can contact the webserver locally. Cannot via external interface. It also has internet routability.
when you access the webserver using the external, public IP address, do you see a translation in the NAT table (show ip nat translation *) ?
NASA#show ip nat translations
Pro Inside global Inside local Outside local Outside global
tcp 71.17.160.174:22 192.168.30.10:22 --- ---
tcp 71.17.160.174:80 192.168.30.10:80 --- ---
tcp 71.17.160.174:443 192.168.30.10:443 --- ---
I can't access it from the outside.... That's what I'm saying.
try and disable the ZBF (by removing the zone member statements from the interfaces) and try to access the webserver from the outside...does that work then ?
try and add the below:
ip nat pool WEBSERVER 192.168.30.10 192.168.30.10 netmask 255.255.255.0
ip nat outside source list 1 pool WEBSERVER add-route
access-list 1 permit any
and change the policy map to:
inspect
I lost all internet connectivity for web browsing. I tried this.
ip nat inside source static tcp 192.168.30.10 80 interface GigabitEthernet0/0 80
ip nat inside source static tcp 192.168.30.10 443 interface GigabitEthernet0/0 443
ip nat inside source static tcp 192.168.30.10 22 interface GigabitEthernet0/0 22
ip nat outside source list 2 pool WEBSERVER add-route
access-list 2 permit any
--- ---                ---                192.168.30.10      172.217.165.10
 Didn't get the internet back until
NASA(config)#no ip nat outside source list 2 pool WEBSERVER add-route
Dynamic mapping in use, do you want to delete all entries? [no]: yes
 Same result
remove:
and disable the ZBF. We need to find out if the webserver is accessible at all from the outside...
Similar concept. I enabled https server.
You can visit https://earth.vastspace.ca/ which is secure server on the cisco box. So the system is reachable.
The server/vm is going over two 802.1Q trunks, and three vland devices. I can reach the internet through it and there is no other security than whats on the router.
I cannot reach the website. Either way, I will lab this and get back with you. It will be tomorrow, as I am in GMT +1, so it is midnight over here...
Thank you sir
Hello
You have a quite convoluted ZBF configuration which could do with a tidy up
- However to gain access instead of using access-lists for the inspection traffic to/from vlan30 and the Internet and just match on the protocol.
Example:
class-map type inspect match-any V30-TO-OUTSIDE-CLASS_NEW
match protocol tcp
match protocol udp
match protocol icmp
no class type inspect V30-TO-OUTSIDE-CLASS
class type inspect V30-TO-OUTSIDE-CLASS_NEW
class-map type inspect match-any OUTSIDE-TO-V30-CLASS
no match access-group name OUTSIDE-TO-V30
no match access-group name OUTSIDE-TO-V30_80
no match access-group name OUTSIDE-TO-V30_443
match protocol http
match protocol https
inspect
class class-default
no drop log
no drop
Kind Regards
Paul
It would appear you are trolling.
@NathanLKoch
What do you mean by that remark?
Kind Regards
Paul
I got HTTP and HTTPS access from the outside to the inside webserver to work with the configuration changes below (marked in bold). Try these out and see if you get it to work. Apparently the class map for the out to v30 needs a parent class matching both protocols...
Building configuration...
Current configuration : 16181 bytes
! Last configuration change at 18:48:28 UTC Wed Feb 12 2020 by nkoch
! NVRAM config last updated at 18:42:38 UTC Wed Feb 12 2020 by nkoch
version 15.7
no service pad
service internal
hostname NASA
boot-start-marker
boot-end-marker
enable
aaa new-model
vlan ifdescr detail
no ip source-route
no ip bootp server
ip domain name earth.vastspace.ca
ip name-server 208.67.222.222
ip name-server 208.67.220.220
HTTP
add
ip cef
ipv6 dhcp pool vlan
ipv6 cef
redundancy
no cdp run
--> class-map type inspect match-any HTTP_HTPS
--> match protocol http
--> match protocol https
--> class-map type inspect match-all OUTSIDE-TO-V30-CLASS
--> match class-map HTTP_HTTPS
--> match access-group name OUTSIDE-TO-V30_80_443
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
inspect
class class-default
--> drop
drop
class class-default
drop
--> inspect
class class-default
drop log
drop
class class-default
drop
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
drop
class class-default
drop
inspect
class class-default
pass
drop
class class-default
drop
interface Loopback0
interface Loopback1
no ip address
interface Tunnel0
no ip address
ipv6 address
ipv6 enable
tunnel mode ipv6ip
tunnel destination
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no mop enabled
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
shutdown
duplex auto
speed auto
no mop enabled
no ip http server
ip dns view default
no ip ssh server authenticate user password
ip identd
--> ip access-list extended OUTSIDE-TO-V30_80_443
--> permit tcp any host 192.168.30.10 eq 80
--> permit tcp any host 192.168.30.10 eq 443
ipv6 ioam timestamp
control-plane host
control-plane
vstack
banner login ^C
banner motd ^C
Welcome to ^C
line con 0
exec-timeout 5 0
speed 115200
line aux 0
exec-timeout 15 0
modem InOut
line 2
exec-timeout 15 0
no exec
stopbits 1
line vty 0 4
password 7
ntp update-calendar
end
actually, for the sake of clarity, I also completed the empty access lists...
The full (hopefully working) config with the changes maked in bold:
version 15.7
no service pad
service internal
hostname NASA
boot-start-marker
boot-end-marker
enable
aaa new-model
vlan ifdescr detail
no ip source-route
no ip bootp server
HTTP
add
ip cef
ipv6 dhcp pool vlan
ipv6 cef
redundancy
no cdp run
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
inspect
class class-default
--> drop
drop
class class-default
drop
--> inspect
class class-default
drop log
drop
class class-default
drop
inspect
class class-default
pass
inspect
class class-default
pass
drop
class class-default
drop
drop
class class-default
drop
inspect
class class-default
pass
drop
class class-default
drop
interface Loopback0
interface Loopback1
no ip address
interface Tunnel0
no ip address
ipv6 address
ipv6 enable
tunnel mode ipv6ip
tunnel destination
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no mop enabled
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
--> ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
ip nat inside
no cdp enable
ipv6 enable
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
shutdown
duplex auto
speed auto
no mop enabled
no ip http server
ip dns view default
ip identd
--> permit ip 192.168.2.0 0.0.0.255 any
--> permit ip any 192.168.2.0 0.0.0.255
--> permit ip any 192.168.20.0 0.0.0.255
--> no ip access-list extended OUTSIDE-TO-V30
--> permit ip any 192.168.40.0 0.0.0.255
--> permit ip any 192.168.50.0 0.0.0.255
--> permit ip any 192.168.60.0 0.0.0.255
--> permit ip any 192.168.70.0 0.0.0.255
--> permit ip any 192.168.80.0 0.0.0.255
--> permit ip 192.168.60.0 0.0.0.255 any
--> permit ip 192.168.70.0 0.0.0.255 any
ipv6 ioam timestamp
control-plane host
control-plane
vstack
banner login ^C
banner motd ^C
Welcome to ^C
line con 0
exec-timeout 5 0
speed 115200
line aux 0
exec-timeout 15 0
modem InOut
line 2
exec-timeout 15 0
no exec
stopbits 1
line vty 0 4
password 7
ntp update-calendar
end
