Highlighted
Beginner
CISCO AIR-LAP1252G-AK9
I have a cisco AIR-LAP1252G-A-K9 Accesspoint but it does not work on.because it shows some error on putty interface and not showing on wifi search.my connectivity structure is
1.console cable connected  AP to PC
2.LAN cable connected Dlink DIR 600 Router to AP Ethernet
3.Power source is a Power Adapter
ERROR LOG shows on Putty Bellow pls help me anybody
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-K9W8-M), Version 12.4(21a)JHA, RELEASE                                              SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Feb-10 12:41 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 11 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31352832
flashfs[1]: Bytes used: 7533056
flashfs[1]: Bytes available: 23819776
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present A600 8000 A8020000 0 A8030000 30
Radio1 not present 0 0 0 0 0 13
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1252G-A-K9    (PowerPC 8349) processor (revision C0) with 49142K/16                                             384K bytes of memory.
Processor board ID FTX1535902D
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 6.0.196.0
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:7D:12:CB:3C
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC15301GGS
Top Assembly Part Number             : 800-29532-03
Top Assembly Serial Number           : FTX1535902D
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252G-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:07.063: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t                                             est passed
*Mar  1 00:00:07.839: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self                                              test passed on interface Dot11Radio 0
*Mar  1 00:00:07.903: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log                                              (contains, 404 messages)
*Mar  1 00:00:09.815: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state                                              to up
*Mar  1 00:00:09.839: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:09.839: %SNMP-5-COLDSTART: SNMP agent on host AP0007.7d12.cb3c is                                              undergoing a cold start
*Mar  1 00:03:14.043: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:03:14.043: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:03:14.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth                                             ernet0, changed state to up
*Mar  1 00:03:14.203: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:03:14.203: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:03:14.519: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r                                             eset
*Mar  1 00:03:15.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio                                             0, changed state to down
*Mar  1 00:03:17.051: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power s                                             ource
*Mar  1 00:03:17.075: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:03:18.055: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio                                             0, changed state to up
*Mar  1 00:03:32.051: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r                                             eset
*Mar  1 00:03:32.071: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:03:32.675: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:03:32.687: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.                                             255 started - CLI initiated
*Mar  1 00:03:42.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
*Mar  1 00:03:52.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
*Mar  1 00:04:02.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
*Mar  1 00:04:12.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
*Mar  1 00:04:22.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
Not in Bound state.
*Mar  1 00:04:32.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does                                              not have an Ip !!
*Mar  1 00:04:32.051: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:04:42.051: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
1 REPLY 1
Highlighted
Beginner
OHHH. Finaly I done with Lightweight to Autonomous Conversion Sucessfully.
