Himanshu Varma
Community Manager
Community Manager
Symptoms
 These are test symptoms
Diagnosis
 These are test Diagnosis
Solution
 This is a test solution
Himanshu Varma
Community Manager
Community Manager
To specify the source interface (if you are pulling the file from a remote site through a VPN tunnel and need the copy to source from the inside interface)
try this:
 copy tftp://1.1.1.1/filename.bin;int=inside flash:
Here is where I got this:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa70/command/reference/cref_txt/c.html#wp1970383
Srisudhir T
This is a good document to test in prod
This is to test the category level ad
