03-17-2023 09:36 AM
According to sd-wan docs VPN 512 is the management VPN. It carries out-of-band network management traffic among the Viptela devices in the overlay network. By default, VPN 512 is configured and enabled. If I'm not mistaken SNMP is kind of management traffic. So, I'm curious wther it is possible to configure another VPN except 512 to carry SNMP traffic?
Solved! Go to Solution.
03-17-2023 09:41 AM
03-17-2023 09:41 AM
03-17-2023 09:48 AM
So if I correctly understand you 512 is default management VPN but except it I can configure another one and disable 512?
03-17-2023 10:14 AM
03-17-2023 10:28 AM
Thank you very much for helping. I'll accept your answer. Just want to ask do you know how I can retrieve all management interfaces via vManage API?
