Checking for syslog in Viptela
knaik99
Command i.e. used to check syslog in Vedge ,ISR,ASR in Viptela sdwan and how can we check syslog in Vmanage
chcortez
The WAN Edges send relevant alarms and events to vManage and you can use an API to query these from vManage.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/Monitor-And-Maintain/monitor-maintain-book/m-alarms-events-logs.html
You may also configure System Logging to stream logs to a syslog server: https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/configure-logging.html
