Combining Viptela and CIsco sdwan vedges
gaurav mahajan1
Hello
Currently we have an existing SDWAN setup with Viptela edges 100B at remote sites and Controllers hosted in AWS.
We are about to onboard few more sites which already have C1111-4P cisco routers.
My question can we upgrade the cisco C1111-4P  to SDWAN software and connect it with our existing controllers
so can the viptela and cisco edges co exist in the same sdwan fabric.
Thank You
Torbjørn
Hello @gaurav mahajan1,
Yes, cEdges and vEdges can co-exist in the same fabric without issue.
Keep in mind that the features supported on cEdges and vEdges differ slightly, so you might need to make some adjustments. You will also have to re-create CLI templates for the cEdges if you are using any.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
