02-28-2022 10:55 AM
I'm using the SD-WAN Documentation page to learn Enterprise Cert Management. https://www.cisco.com/c/en/us/td/docs/routers/sdwan/config/vEdge-sdwan20.html
The Cert Management is under "Installation and Getting Started." I used the drop down to select different versions because I know there are distinct features that have become avail with each major release. What's happening is that although I have selected a distinct version, I am sent to the same page. Somewhere in all this documentations there has to be a "Recommended" solution for which Root CA is supported/recommended.
The SD-WAN controller Certificates and Authorized Serial Number File Prescriptive Deployment Guide for a Enterprise Root Cert CA does not identify a recommended Root CA platform either.
"Some examples include Linux-based XCA, TinyCA, or OpenSSL (which is part of all Linux distributions) or Windows (where you can install an Ubuntu shell or OpenSSL)"
Does Cisco have a recommended Enterprise Root Cert platform? Or maybe they did and subsequent versions have included others? I am not able to find in any docs.
Thx
03-01-2022 04:32 PM
03-02-2022 06:21 AM
03-02-2022 10:58 AM
