How to send faulty power supply/fan notification alert to webhook
yako
hello,
I just enabled email/webhook notification on vManage in order to send some alerts such as faulty power supply or fan failure alarm to the webhook server, however, I don't see any hardware alert except interface down, OMP down, BFD down...
 please could you help?
2 Accepted Solutions
For power supply you need to collect syslog messages:
CHMGR_PEM_OK
CHMGR_PEM_OPER
On this case you need to create/edit cflow policy and send the logs to a server.
Login into V-MANAGE,
- Click on "Configuration" on the left panel
- Scroll down to "Policies"
- On the upper right hand side select "Custom Options"
- Cick on "Traffic Policy"
- On the left upper side click on "Cflowd"
- Click on Policy "CFLOWD-POLICY" and click on the 3 dots on the righ hand side
-Or you need to click "Add Policy" in case you have none.
- Click on "Edit"
- Click on "New Collector" on the left hand side
Once new template open,
- Vaidate the template with its address just created
- Netflow (LogicMonitor) X.X.X.X
- On the Template go to middle right hand side "Action"
- Click on Delete, confirm and save changes
CHMGR_PEM_OK
CHMGR_PEM_OPER
yako
Hello Flavio,
thank you for taking your time to reply to me.
please do you have any documentation providing step by step how to create/edit Cflow policy and send the logs to a server?
- Click on "Edit"
Thank you so much
