ISR1100-4GLTENA From IOS-XE to Viptela
mbaker33
A few months ago I received two ISR1100-4GLTENA devices and instantly converted them to IOS-XE because that is what needed to happen in the moment to deploy them.  Now, however, we are working on deploying Cisco SD-WAN with Cisco Cloud Managed vManage/vBond/vSmart devices.  It doesn't appear as if the IOS-XE device is supported (only the Viptela OS equivalent) so I am trying to convert it back to Viptela OS but I cannot find a document to help me out.
Any suggestions?  Is it as easy as uploading the vEdge file to the bootflash and booting from it?  That seems sort of sketchy.
inderdeeps
Level 4
Level 4
FesterRancid
Support for IOS-XE SD-WAN for the ISR1100 came in with the 17.4 code.
