Lan ports of ISR 1100
almccanuel
Hi All,
TIA, i just want to verify if possible to configure L3 on LAN port of ISR 1111x-8P? i have a sdwan setup and my 2 wan ports is connected to DSL and MPLS. and my LAN side i would like to have a point to point routing from my isr 1k going to core. is thus setup possible?
Yes.
First add a "VPN Interface SVI" template to Service 1. This will be your Layer 3 configuration.
Now you need to add the "Switchport" template. In there, add the interface you're using for the p2p and make it an Access port.
Done.
