Loading current IOS on 100b vEdge
benwexler1
I have some 100b with older code 15/16.x and vMAnage will not recognize them. How do I manually update the code to 19.x or are there a series of commands to force it to recognize vMange?
thanks in advance,
Ben
Yes, Ben.
Same applies for 16.x too.
The latest image that is available on CCO Software download page is: 18.4.4
Hope it helps.
svemulap@cisco.com
Ben -
15.x is really old. Going back to Viptela days of 2015 !!
You need step upgrade, so vEdge can talk to vManage on 19.x version.
It requires at a high level to go from 15.3.8 -> 16.2.10 -> 17.2.8 -> 19.x 9
(some thing like it)
Some of these images are not even posted anymore on cisco.com<>
Best option is open a TAC Case on this to get the vEdge to an image where it can talk to vManage.
Hope it helps.
benwexler1
Thank you for the reply. Same recommendation for the units on 16.x code.
My next step was a TAC case.
thanks again
Ben
Yes, Ben.
Hope it helps.
