03-16-2021 01:12 AM
Hi Guys,
I am very new in cisco sdwan hope someone can help me here.
I changed the system-ip and site-id of my vedge then suddenly i noticed my vedge is unreachable in vmanage or even i tried to ping or ssh it in my local laptop.
is this the normal outcome when changing system ip or site id? If, yes what can i do to bring it up again?
thank you.
03-16-2021 11:19 AM
04-04-2021 05:16 PM
I think you should login via console to check the configuration again. Site id is very important based on the routing policies you defined. Check the parameters via console and think twice as a design when changing.
Inderdeep
