max sdwan tunnels supported
avdheshkumar
Hi All,
plannign to deploy sdwan for around 100 sites with cat8300 routers at each site. can you help me with the max number of tunnels supported .
Avdhesh
  You can check on this device datasheet but the capacity will not be given in tunnels capacity but in IPSEC capacity. Which, on this router, is " Up to 5 Gbps of IPSec".
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/datasheet-c78-744088.html
But, the place you really need to worry when design SDWAN is the controller capacity.
For example:
"On-Premise deployments can be hosted on either ESXi or KVM hypervisors, with even the smallest footprint requiring a minimum of 16 vCPUs, 32GB of dedicated RAM and 500GB of storage. Now you can see why the cloud hosted option is so appealing. A single vManage instance can support up to 2,000 devices and can be deployed as part of a cluster containing 6 instances."
https://www.lookingpoint.com/blog/cisco-sdwan-architecture-components
cdoughty
So, there isn't a maximum number of tunnels then?  I would think each tunnel would add CPU and Memory consumption to maintain the BFD telemetry, keep-alive, etc.  If you have 100 sites each with 2 transports unrestricted, that would be nearly 400 tunnels on each device.
pdebreczeni
For the record, there is a limitation, check Table 3. in the datasheet. "SD-WAN Overlay Tunnels scale"
