MX64 not coming online
BHconsultants88
Hi everyone
I'm afraid this is rather basic but I just can't work out why my Meraki MX64 isn't coming online. I'm introducing it to an existing LAN so that it sits in between the modem and the LAN. The problem I'm having is that I can't even get it connected to the cloud. I think I'm doing everything right but just wanted to clarify.
The BT DSL line is connected (RJ11) to a Draytek Vigor 130 modem. There is one LAN port on the Draytek. I've given the Draytek a static IP address of 10.20.21.253. The existing LAN router has an IP address of 10.20.21.1 and my MX64 will be 10.20.21.254 (statically assigned).
So:
Draytek LAN 10.20.21.253 >>>>>>> MX64 Internet port >>>>>>> 10.20.21.254 >>>>>>>>>> LAN router 10.20.21.1
If I connect the MX directly to the LAN switch (10.20.21.249), it connects to the cloud immediately. Could anyone tell me why my MX not connecting to the cloud?
Francesco Molino
I understand when you said you connected your internet MX64 port into your modem but I didn’t understand why and how you connected it to your LAN router. They all are in the same subnet. Do you have a switch connecting them?
What is the default gateway you set on MX64?
Can you detail a little bit your physical connectivity?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Many thanks for the reply. I've attached an overview of the network.
I think this should work but just wanted to check I hadn't missed anything.
Thanks very much.
You're using the same subnet on the internet port of MX and on the LAN? This won't work.
If you disconnect your LAN router temporarily, your MX will register to the cloud. Please check it out.
Then you can reconnect them but change subnet
Francesco
