On Prem SD-WAN validated design
williamae
Hi folks,
I am trying to understand what is the best way to deploy Cisco SD-WAN modules (On Prem) so that I don't expose vManage and vSmart to the internet unnecessarily. My preference would be the following and this is based on my understanding from Cisco Press SD-WAN book:
vManage: 192.168.1.100 > Dynamic NAT to a public IP address /* Do I have to? I am under the impression that vBond will do the talking and vSmart will communicate to the vEdges via OMP. Do I still need vManage to talk directly to vEdges?
vSmart: 192.168.1.101 > Dynamic NAT to a public IP address
vBond: 192.168.2.100 > Static 1:1 NAT to another public IP
vManage,vSmart and vBond in CLI and GUI is set to 192.168.2.100
IP address of vBond that I enter in vManage CLI and GUI, as well as vSmart CLI should be 192.168.2.100 - technically.
I have setup with this design however vEdge does not register in vManage. I see that it tries to reach vManage on 192.168.1.100 from a public network which is not right. My understanding is that this should not happen at all because vBond is acting as a relay.
***Please note that a Cisco ASA is taking care of the zones*** I also tried with a Cisco router with no zoning or firewall capability and no joy.
My second attempt was to assign each controller, a static public IP (again just to get things to work but really don't like this idea. I still prefer to lock vManage completely down with no Internet access except for license renewal from time to time).
vManage: 192.168.1.100 > Static 1:1 NAT to public IP X.X.X.100
vSmart: 192.168.1.101 > Static 1:1 NAT to public IP X.X.X.101
vBond: 192.168.2.100 > Static 1:1 NAT to public IP X.X.X.102
Result of this test was also a failure. I see vEdge is still trying to reach to vManage on random ports on UDP with 192.168.1.100 address which is wrong.
Third attempt was a not-so-lovely combination of Public IP addresses and NAT with Cisco ASA.
vManage: 192.168.1.100 > Dynamic NAT to a public IP address IP X.X.X.101
vSmart: 192.168.1.101 > Dynamic NAT to a public IP address IP X.X.X.101
vBond in CLI and GUI of the whole setup is set to public IP X.X.X.102
I NATed outbound vManage and vSmart traffic to reach vBond with a Public IP address and vBond also responds with a Public IP address to vManage. Again not desired at all but this test also failed.
The only time I got the result was to place the vEdge in the same broadcast domain as vManage, vBond and vSmart.
Now I am trying to understand, the logic behind on premise. Reading Cisco official book doesn't exactly say what is the validated design. Should I let the controllers to talk to each other with Public IP addresses? Should I translate them and if I should, what will be the correct IP for vBond in the setup? Private or the public IP?
Could anyone help me understand the concept a little better?
Thanks.
0 Replies 0
