12-16-2019 07:55 AM
I am building on premise SDWAN setup, All the controllers (vManage,vBond,vSmart) are up and running on DC VLAN (Which is my Service Side VPN). The edge devices are not able to communicate with controllers as they are sitting in my DC network. What options do i have to get this working. Attached is topology of my setup.
Faisal
12-16-2019 08:27 AM
Hi shhaldar,
Thank you. This document would be of great help when configuring policy. I am stuck with placement of controllers.
12-25-2019 02:33 AM
Are you using VPN 0 to connect them ? are all these able to build control connection with each other ?
12-30-2019 07:38 AM
12-30-2019 08:32 AM
12-31-2019 07:09 AM
Dear faisal.memon
Kindly read the below link, you will have a good understanding for CISCO Vipetal sdwan on-prem controllers deployment for cEdge/vEdge routers.
https://community.cisco.com/t5/sd-wan/sd-wan-controller-hosted-on-prem/m-p/3959525#M1447
Let me know if you still have any queries or doubts, will help you resolve the issue.
If you think that my post has answered your questions, kindly hit the helpful button and mark as a solve.
Rohit Raj
01-06-2020 04:51 AM
You can have a look at this Cisco Live presentation.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/BRKRST-2559.pdf
Let us know if it helps.
Best regards,
04-15-2020 04:28 AM
The first step for you would verify the connectivity in between one of the Edge routers and your Bond controllers. these are possible options on vBond controller:
Once you verify above, review below options on a given Edge device:
Last but not least, confirm if there is any firewall in between and if that firewall might be blocking control connections.
Let me know how did you go.
08-17-2020 08:56 PM
Hello. Did you find a solution?
I am stuck with this too. It worse I don’t see people helping much. Most of the post doesn’t have answers.
In my case I don’t have connectivity between VEDGES devices. I am doing On-Premise deployment with a vedge in-line, and firewall in the middle. I followed all the guides and nothing helpful. The best source for knowledge at this moment is through Cisco live.
cheers
02-16-2023 09:54 AM
Hi!
Did you solve the issue?
i’m struggling with exactly the same issue
02-18-2023 05:26 AM
Hello
From vM,
devices -device -device bring Up
SSH in v/cEDGE
show control local properties
show control connection-history
02-20-2023 09:50 AM
Hi Paul
Thanks for your response.
I’m working on the design so there's not deployed devices yet.
I need to plan before implement.
Regards!
