09-28-2020 05:16 AM
I am looking for a modern branch office network design.
Below are the key design criteria.
1) The branch office will be shared by multiple group company users.
ex - There will be users from 3 group companies sharing the network. But they need to be logically separated. (Segmentation)
2) Each group company user will need to access their respective resources in their DC
3) Common Guest WiFi Internet Access is rquired
What is the ideal cost effective design for this. ?
Will SD-WAN fit into this requirement .
09-28-2020 12:36 PM
09-28-2020 06:01 PM
Thanks. I understood.
In Data Center , we do have SD-WAN & it can be used as part of it.
I understand from the WAS perspective SD-WAN is the way to go as it also provides segmentation.
Regarding LAN side how similar segmentation is achieved for different group companies.
Is VRF the only option or is there any other option at LAN side which needs to be considered for the design.
