Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
280
Highlighted
Participant
SD-WAN DIP
In my scenario I am planning to achieve the below so that office 365 takes the best path.
To achieve this let me know is it required to enable DIP.
Is DIP required to be enabled to  achieve this ? Can this be achieved without DIP ?
2 REPLIES 2
Highlighted
What do you mean by DIP? Do you mean DPI (Deep Packet Inspection)? If yes, it will be enabled automatically of you configure cloudexpress. It's required to identify SaaS applications, you don't need to enable it manually.
Highlighted
Beginner
I have the same problem as RS19 has mentioned. I'm using IS4331 with IOS XE-SDWAN 17.2.1v and vManage / vBond / vSmart 20.1.12 located on Cisco Cloud.
The DPI is not working and I don't have idea what is missing.
Someone has any idea what could be the problem? (I've attached a caption from DPI dashboard)
Content for Community-Ad
