02-20-2019 04:46 PM
At present the Cisco document says the below features are not supported in IOS XE
What is the difference between Express service vs onRamp service ?
02-20-2019 06:28 PM
Cloud Express Service is Cloud onRamp for "SaaS", the solution can adjust dynamically and intelligently move SaaS traffic to the updated optimal path based on Application on Cloud such as Dropbox , O365 , Sharepoint , Google
Cloud OnRamp Service is Cloud onRamp for "IaaS", Cloud OnRamp for IaaS extends the fabric of the Viptela overlay network into public cloud instances, allowing branches with vEdge routers to connect directly to public-cloud application providers. Cloud OnRamp for IaaS works in conjunction with AWS virtual private clouds (VPCs) and Azure virtual networks (VNets).
02-20-2019 06:43 PM
Thanks. Got it.
To achieve the below for O365, is it required to enable DPI functionality ?
