Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
1637
sinaa._.ak
Beginner
SD-WAN License for ISR 4221 & 4431
Hi everyone
i have an isr4221 & isr4431
do these routers support ipsec in sdwan deployment with vmanage
or i must buy this license?: SL-44-SEC-K9
Another question
Does ISR4431 support performance license in sdwan deployment?
tnx in advance
1 ACCEPTED SOLUTION
daniel.dib
Rising star
You need a DNA license to run SD-WAN code. IPSec is part of that license and you don't need a separate one. There is no policer restricting you from using the full performance of the device. You don't need a performance license. The device will push as much traffic as it is capable of. The license you get is based on how much bandwidth you are planning to use.
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
5 REPLIES 5
daniel.dib
Rising star
Daniel Dib
CCIE #37149
CCDE #20160011
tnx for your answer
in the case of sdwan i dont use dna for manage my deployment. I use vmanage instead and it works without license
I'm not talking about DNA Center. I'm talking about DNA Essentials, Advantage and Premier which are the licenses you would use for a SD-WAN deployment. What works and what is legal are two different things.
Daniel Dib
CCIE #37149
CCDE #20160011
Hi sinaa._.ak,
Please refer to the link below for the DNA license options:
https://www.cisco.com/c/dam/en/us/products/collateral/software/dna-software-routing-subscription.pdf
Regards, JW
Content for Community-Ad
