ā02-21-2021 03:44 AM - edited ā02-21-2021 04:36 AM
Hello All,
Is SD-WAN speed test supported on ISR 4331 and C1111?
To enable speed test (data stream from settings), is it must to add the vManage IP (either vpn 0 or 512) or do we have other options?
Solved! Go to Solution.
ā02-22-2021 09:32 AM
it is not supported on cEdges, it is only natively supported on vEdges as they run IPerf in the vshell.
ā03-06-2021 07:25 AM
Hello All,
Just to keep this post updated with the latest, with the help of someone from Cisco found that speed test will be supported on 17.2.x for Cisco IOS XE SD-WAN devices.
This is the release notes: https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-17-2/ios-xe-sd-wan-re-notes-17-2.html
ā02-24-2021 12:39 AM
Thanks Oscar
Hello All,
ā03-08-2021 01:31 PM
The below article may help you to test the speed via CLI
https://www.thenetworkdna.com/2021/02/cisco-viptela-sdwan-speed-test-via.html
Inderdeep Singh
ā03-11-2021 03:10 AM
Thanks for the information
