SDWAN - configuration push
praveen-CCNP
when I pushed the configuration from manage, it has been pushed the OSPF configuration but rolled back to default with in 3 mins without any errors.
please share your suggestions to troubleshoot. I am new to SDWAN
18 Replies 18
praveen-CCNP
I should turn off OMP at this stage ?
omp
no shutdown
graceful-restart
advertise connected
advertise static
Omp between vedge and vsmart this not effect
You use ospf under vpn0 which breaks connect from vedge to vmange and/or vsmart
There is something wrong in ospf you use for vpn0.
MHM
can you share topology? what is the purpose of OSPF in underlay if you have static route?
can you share show control connections and show control connection-history during issue is happening?
HTH,
