SDWAN routers not accessible over CLI
avdheshkumar
Hi Team,
i had a SDWAN lab setup with 1 x ISR1100  and 1 x ISR4331 routers in controllers mode and running in fabric. due to some reason we removed the controllers and missed de-borading the routers.
now the routers are not reachable on network (via LAN) and we are not able to get console access as well.
can anyone suggest a way to recover these routers.
BR
balaji.bandi
You still should able to access the Router IP using SSH and console :
If you like to remove the Router from network then follow below procedure :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/install-upgrade-17-2-later.html#change-console-port-access-after-install--controller-mode
BB
balaji.bandi
BB
avdheshkumar
Thanks Balaji for the reponse, I noticed the status LED is amber and while taking console it shows an error regarding memory and hangs there. raised an RMA for the same.
