09-28-2020 04:03 PM
Hello Team
Can you provided me any reference as to how provision subinterfaces on VPN0 transport?
The design consist of integrating two Internet services using the same interface which connects to a firewall.
Thanks a lot for your help
09-29-2020 01:17 PM
have you checked the configuration guide or End-to-End deployment Guide? you need to add 4Bytes for the Parent Interface MTU.
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/SD-WAN-End-to-End-Deployment-Guide.pdf
(check page 94)
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge/systems-interfaces-book/configure-interfaces.html
Can you also use loopbacks instead? it might be another option for your deployment
Log in to Community
