Vbond 19.2.4
Juraj Papic
Level 3
Level 3
Hi all,
Im with the following issue
Vbond# show orchestrator valid-vedges
% No entries found.
The Certificates are installed correctly.
Thanks.
you should have valid vedge list uploaded to vmanage (or synced via smart account -> this option may not be in 19.2.4 ,old release I dont remember). And list should be sent to controllers. If already there, try to re-send and check on vbond.
Ensure that you have true control connection between vbond and vmanage .
HTH,
HTH,
Hello ,
I have a connection between vmanage and vbond
as I said, try to resent certificate list controllers again from vmanage GUI.
HTH,
HTH,
