vEdge Up and Down on vManage
UlquiorraCifer
I have problem with add vEdge to vManage. Status on vManage is up and down sequence. And when i show on vedge " Show control connection-history " have  fault :  RXTRDWN/DISTLOC. So how can i fix this ?
ekhabaro
RXTRDWN/DISTLOC this is temporary event reflected in the Show control connection-history. If your control connections are flapping, then check connectivity, most likely you have reachability problems. RXTRDWN/DISTLOC is not an indication of an issue by itself, it's something else.
ekhabaro
Thanks u.
I got a similar issue on a vEdge, control connection UP/DOWN constantly, the software version of the vEdge was to old and not compatible with vManage version, once i did an upgrade to a supported version the problem was fixed.
