Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
1580
Highlighted
Beginner
vManage Certificate Failure
Hello
I am trying to install the certificate for vManage controller but getting the following error
Failed to retrieve device data
Failed to find device with uuid null
I've tried the following methods to create a certificate but getting same error message
- Windows Server CA
- XCA
- OpenSSL
Any thoughts on this issue ?
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: vManage Certificate Failure
Use following steps for Certificate installation for vManage:-
For lab you can use openssl:-
Go to vManage CLI-->
vManage#vshell
vmanage:~$
->generate the Root CA certificate. First login to the vshell which is a Unix like shell. Login with the vshell command.
-> To Generate a Root CA key use following command :-
     openssl genrsa -out ROOTCA.key 2048
->Next generate the Root CA certificate. I will generate a certificate with 5 years of validity use following command:-
     openssl req -x509 -new -nodes -key ROOTCA.key -sha256 -days 2000 \ -subj "/C=AU/ST=NSW/L=NSW/O=sdwan-testlab/CN=vmanage.lab" \ -out ROOTCA.pem
-> This will create a Root CA cert named ROOTCA.pem cat the file contents so you can copy and paste under
     administration->settings->Enterprise Root Certificate box and click on import&Save.
-> Keep the WAN Edge Cloud Certificate Authorization method as Automated (vManage - signed Certificate). This way the vManage will automatically signed the cloud edge certs when they connect to the vManage.
->Next we need to create a CSR for the vManage. Navigate to the certificates section.
  • Configuration->Certificates->Controllers->vManage->click on "..."->Generate CSR.
  • A window will popup with the CSR text, copy that CSR text and  Sign vManage generate CSR with the ROOTCA.key and ROOTCA.pem.
  • Back in the vshell there will be a file called vmanage_csr. Sign this file with the ROOTCA.key and ROOTCA.pem, use following command to sign the CSR with ROOCA.key and ROOTCA.pem:-
       " openssl x509 -req -in vmanage_csr \ -CA ROOTCA.pem -CAkey ROOTCA.key -CAcreateserial \ -out vmanage.crt -days 2000 -sha256"
  • This creates a file called vmanage.crt cat the file in order to copy and paste it into the web interface in the next step.
  • copy and paste the Signed CSR  into the web interface in the next step.
  • Navigate to the certificates page and install the certificate by pasting the contents of the vmanage.crt (Signed CSR) file and click Install.
  • Configuration->Certificates->Controllers->vManage->Install Certificate.
  • You should see a success message.
This is how you can use OpenSSL and follow the same process for Windows CA.
Let me know if you have still doubt in it. Hit Helpful button if this post has helped you.
Thanks and Regards,
Rohit Raj
Rohit Raj
Everyone's tags (1)
11 REPLIES 11
Highlighted
Beginner
vManage#vshell
vmanage:~$
Thanks and Regards,
Rohit Raj
Rohit Raj
Everyone's tags (1)
Highlighted
Beginner
Hi Rohit
we can continue the discussion here when specifically it is related
here is lab details and vmanage configuration
Also I have attached the diagram
For certificate I followed the steps as you mentioned and also I used OpenSSL and XCA but experienced same issue
the lab is running on EVE-NG emulator
system
 host-name vManage
 system-ip 10.255.255.1
 site-id 51
 organization-name “SAM SDWANLAB”
 vbond 1.1.1.3
vpn 0
interface eth 0
ip address 10.0.0.2/24
ip route 0.0.0.0/0
no shut
vpn 512
interface eth1
ip address 192.168.66.2/24
no shut
Domain controller/DNS/Cloud 512 is connected to VPN 512 Cloud
Highlighted
Beginner
There must be something you are missing, i want to know what are following for certificate also i can see the vBond ip address is wrong. If you want i can help you remotely if you can share the screen, will resolve the problem for you.
Rohit Raj
Everyone's tags (1)
Highlighted
Beginner
I simulating controllers behind NAT therefore I have added the public IP of vBond.
Please let me know whenever you are available so I can send PM you the remote session details.
Highlighted
Beginner
I am available now.
Rohit Raj
Everyone's tags (1)
Highlighted
Beginner
I was able to successfully able to install the certificate with excellent support from Rohit Raj.
He was very helpful on a remote session.
Thanks Rohit Raj. I highly appreciate your time and efforts.
Highlighted
i have the same issue
when i install certificate on Vmange i get the following message .
fail to retrieve device data
failed to fined device with uuid null
i tried to do same as you have described above
any advice will be appreciated
thank you
Highlighted
Beginner
Rohit Raj
Everyone's tags (1)
Highlighted
Beginner
let me when we can connect? ping me,
Rohit Raj
Everyone's tags (1)
Highlighted
Beginner
For case failed to fined device with uuid null,
In Administration menu, select Controller Certificate Authorization and then select Enterprise Root Certificate. Check the Set CSR Properties and in Domain Name box write: viptela.com. And save it.
Then go to the Configuration menu and click on Certificates. In next page click on Controllers tab. After this for every controllers Generate CSR and with a CA-SERVER generate the certificate.
Now you can do your request for Install Certificate over controllers.
Highlighted
hello, hope you will find my msg In good health.Currently i am am deploy SD-wan setup. I installed vmanage vbond and vsmart  and configure their system setting that are listed below.
hostname ---
Organization name ----
site id -----
system IP ----
ntp server ---- prefer vpn 0
clock time zone ----
After that i created my own root CA and signed the CSR to generate cert, and install these certs on controllers. Furthermore, I send them to vbond all work fine until this point but when i made the tunnel interface on vmanage and vbond control connections are not showing up because i got "token inalid" and "certificate-validity     Not Valid - unable to get local issuer certificate". Please help me ou thanks
