Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
837
Vmanage Downgrade
Dear Cisco Community ,
i want to downgrade my Vmanage from 19.2.3 to 18.4.5 , initially i was having 18.4.5 version but i upgraded it to 19.2.3 and now when i try to downgrade this to again 18.4.5 my vmanage reboots and again come with 19.2.3 .
can any1 share my docs or process to downgrade would be helpful
Thanks in advance .
4 REPLIES 4
sasig
Because, downgrade from one major release to another is not supported. For lab testing, you could have taken the snapshot of the 18.4.x image, take a config-db backup and save it offline THEN upgrade. So, you could revert back, it works but not supported
Thanks @sasig  for reply ,
So in short downgrade is not support for vmanage  , correct me if iam wrong .
i didnt took any snapshot of previous version .
That is true, there are a lot of things with upgrades in general; Security patches, configDB, Stats/ElasticDB, Yang changes etc..
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/SD-WAN-End-to-End-Deployment-Guide.pdf
(page 40)
Thanks for your valuable reply ,
still i have one more issue and its a lab environment so i cant raise tac ticket .
scenerio 1 ;- i had controllers and vedge on 18.4.5 and everything was working fine , i upgraded controllers from 18.4.5 to 19.2.3 now the vedge which already added to controllers are working but i am not able to add any new vedge .
iam not sure what iam missing .
Thanks in addvance for your reply .
