07-23-2022 09:38 AM
Anyone got any idea about how to use vManage draft mode for templates?
Solved! Go to Solution.
07-24-2022 04:17 AM - edited 07-24-2022 07:03 AM
Hello cloudlogics,
Before you know how to enable the Draft Mode, it's important to understand the problem that is being solved with this feature.
Please remember that you have CLI templates (containing the full operational device configuration) and Device Templates (which are a collection/aggregation of several Feature Templates, and can be attached to multiple devices).
The Draft Mode feature applies to Device Templates.
Prior to enabling this feature (Draft Mode disabled):
With Draft Mode enabled:
So, to enable Draft Mode:
Note: you can always cancel the implementation of the changes by the end of the workflow in case you need to add another change or if you decide to not implement the changes for some reason.
If you wanna try this feature, please consider doing so during a MW. You could generate a copy of your original template (prior to enabling draft mode) to easily roll back if required. If you are having a non-critical site or a testing site, then that would be the ideal one to choose while you become familiar with the feature.
I hope this helps. Please let me know.
07-24-2022 02:37 AM
07-24-2022 03:21 AM
Hi - Thanks for your reply. Sorry my question was more around how to enable draft mode and how to use it. Just wondering if there is a guide available?
Hello cloudlogics,
07-24-2022 07:35 PM
