ā06-04-2021 02:58 AM
Hi all
I'm trying to install an SD-WAN lab POC but i'm having problems.
I've followed a variety of guides online, i'm building up on my lab ESXI 6.5 host - most lab guides are using EVE-NG but I dont want to use that as it's not how you'd build it out in production
Im using the recommended software versions from Cisco (20.3.3)
I've done as follows:
Install VMs for vManage, vBond, vSmart
Deployed a basic configuration - all devices in the same subnet, using VPN0. The interfaces are all set to "no tunnel-interface" at the moment.
Generated certificates using openssl on vManage
Connected the vBond and vSmart to vManage "controllers" page and configured the certificate from there
I got to the following page but the details don't populate:
I can't see any useful errors (the notification section of vmanage is just complaing about licensing but I don't think I've got to that stage yet?)
I can SSH From the management machine to the vBond (10.0.0.50), vManage (10.0.0.100) and vSmart (10.0.0.200)
When I edit the settings and type in the username/password/IP it accepts the details so it must be making a connection but the info (e.g. IP address) isn't populated ...
Any ideas?
Solved! Go to Solution.
ā06-04-2021 04:19 PM
Rebuilt it with version 20.4.1.2 and it worked ;\ no idea why...
