Way to transfer file to SD-WAN vEdge
kay.kang
I want to transfer file to vEdge device from vmanage or file server( i.e> FTP or SFTP) using any CLI command on vEdge.
I referred to below document but transferring file from vmanage to vEdge was pretty slow(uploading into vEdge).
https://www.cisco.com/c/en/us/support/docs/routers/vedge-router/217948-transfer-files-between-a-vedge-and-vmana.html
Is there any way to download file on vEdge(# or vshell mode)?
Can you give vshell command?
Actually, this part works for vEdge too:
https://www.cisco.com/c/en/us/support/docs/routers/vedge-router/217948-transfer-files-between-a-vedge-and-vmana.html#anc58
Use WinSCP to copy from local computer to vEdge (I tested with vEdge-cloud it works).
Protocol: SFTP
Port: 22
Username/password: admin/respective_pass
If you want to do update from transport interface, ensure that tunnel-interface has allow-service sshd.
HTH,
