Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
140
Beginner
Cisco SDWAN cEdges for Internet Breakout (DIA) and 4g failover
Hi ,
I am working with few customers who are terribly dissatisfied with the lack of ability on Cisco ISR c1111-8p routers to do the following:
>Direct internet breakout (which is supported through local-tloc function on vEdges but not available in cEdges) for traffic types including SaaS traffic that breaks-out/directly goes to the internet
>Automatic failover to 4G (as a backup standby connection) from the primary circuit (as this is supported through last-resort in vEdges but not available in cEdges)
do we have tested/validated workarounds for the following on cEdges or vEdges the only way to go till when cEdges will have a new code( which i believe will be out in Mar 2020).
Thanks experts!
Kris
1 REPLY 1
Beginner
Re: Cisco SDWAN cEdges for Internet Breakout (DIA) and 4g failover
Hi krsnadm
Regarding your questions here's some solutions that can adapt to your scenario
For this you can configure a static default route pointing to the VPN 0, it will be something similar to route leak from vrf to global on regular IOS. This can be achieved also from the Service VPN template. The output will be similar to this
ip nat route vrf 10 0.0.0.0 0.0.0.0 global
router#show ip route vrf 10
Routing Table: 10
<snip>
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
n*Nd 0.0.0.0/0 [6/0], 1d17h, Null0
10.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
router#ping vrf 10 google.com
Sending 5, 100-byte ICMP Echos to 172.217.168.174, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
router#show ip nat translations
Pro Inside global Inside local Outside local Outside global
udp x.x.x.x:5062 x.x.x.x:59524 8.8.8.8:53 8.8.8.8:53
icmp x.x.x.x:5 x.x.x.x:5 172.217.168.174:5 172.217.168.174:5
Total number of translations: 2
This supports failover from the DIA to the Overlay, and follow the regular OMP routes you have on the router.
However this is for all traffic, if you need to have for example all RFC1918 routes going through the DC you'll need static routes for this. Also I've tested this but it's a nightmare, you can have instead of the default all specific public space addresses that you need local breakout.
Another this regarding this, is that we've this working on an ISR1111X-8P, on the 8PLTEEA it doesn't work, at least up until 16.11, I already have the solution on 16.12 but haven't tested it out yet.
This is supported since 16.11 on the cEdges, I have a solution where I have 3 TLOC, MPLS, INET and LTE as backup.
router#show sdwan control local-properties
personality vedge
sp-organization-name xxxxxxx,xxx
organization-name xxxxxxx.xxx
root-ca-chain-status Installed
certificate-status Installed
certificate-validity Valid
certificate-not-valid-before Mar 23 07:55:00 2018 GMT
certificate-not-valid-after Aug 09 20:58:26 2099 GMT
enterprise-cert-status Not-Applicable
enterprise-cert-validity Not Applicable
enterprise-cert-not-valid-before Not Applicable
enterprise-cert-not-valid-after Not Applicable
dns-name xxxxxxxx.xxx
site-id xxxxxxxxxx
domain-id 1
protocol dtls
tls-port 0
system-ip x.x.x.x
chassis-num/unique-id C1111-8PLTEEA-xxxxxxxxxx
serial-num xxxxxxx
enterprise-serial-num No certificate installed
token -NA-
keygen-interval 1:00:00:00
retry-interval 0:00:00:19
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped TRUE
time-since-last-port-hop 0:00:22:54
embargo-check success
number-vbond-peers 1
INDEX IP PORT
0 x.x.x.x 12346
number-active-wan-interfaces 3
NAT TYPE: E -- indicates End-point independent mapping
A -- indicates Address-port dependent mapping
N -- indicates Not learned
Note: Requires minimum two vbonds to learn the NAT type
PUBLIC PUBLIC PRIVATE PRIVATE PRIVATE MAX RESTRICT/ LAST SPI TIME NAT VM
INTERFACE IPv4 PORT IPv4 IPv6 PORT VS/VM COLOR STATE CNTRL CONTROL/ LR/LB CONNECTION REMAINING TYPE CON
STUN PRF
Cellular0/2/0 0.0.0.0 0 0.0.0.0 :: 0 0/0 biz-internet down 2 no/yes/no Yes/No 2:14:12:15 0:00:00:00 N 5
GigabitEthernet0/0/0.4030 x.x.x.x 12366 x.x.x.x :: 12366 1/1 mpls up 2 no/yes/no No/No 0:00:00:04 0:09:47:10 N 5
GigabitEthernet0/0/0.900 x.x.x.x 12366 x.x.x.x :: 12366 1/0 public-internet up 2 no/yes/no No/No 0:00:00:01 0:11:37:11 N 5
Regarding your last point, the main source for that will be your Cisco SE.
Please rate helpful posts.
Thank you
Best Regards,
Content for Community-Ad
July's Community Spotlight Awards
