05-10-2019 07:33 AM
Hi Everyone,
I am in need to have an default route via an exit interface. ( example: ip route 0.0.0.0/0 Dialer10) how can we achieve this in Viptela. Even via Command line, i could not find any option.
The above scenarios is based on IOS-XE SD-WAN 16.10.2
I found a way via Command line, though.
Under the dialer interface, provide the command "ppp ipcp route default" which works fine. but i want this to be managed via vManage. can any one help for the following
1) how to put default route via an exit interface (dialer 10)
2) how to provide the command "ppp ipcp route default" via template.
Solved! Go to Solution.
05-12-2019 12:28 AM
You can add interface name as a next-hop in VPN feature template.
As for "ppp route default", it should be there if you use "VPN Interface DSL PPPoE" feature template.
05-12-2019 12:28 AM
05-12-2019 12:57 AM
I am using PPPoA template and not PPPoE and the device that i have selected is C1111-4PLTELA. I am unable to find this function under these template. But the default route with the exit interface defintely worked for me and thanks for the solution.
