Hi everyone
I'm having an issue whereby my clients connected to a Meraki MS225 switch (via MR42 AP) are unable to connect to a local printer.
This is the scenario
VLAN 100 - 10.10.10.0 /24
VLAN 900 - 192.168.100.0 /24
Local printer - 192.168.100.5
VLAN 900 is effectively the guest network and this LAN requires printing facilities but is not allowed to use the printer on VLAN 100. VLAN 900 users connect to the Guest SSID and pick up an IP address from Meraki DHCP (NAT mode). They receive 10.*.*.* address and have full Internet access. The only problem is the printer.
The printer in VLAN 900 has a static IP address of 192.168.100.5. I've added a rule on the firewall allowing access from VLAN 900 to this IP address but still VLAN 900 users are unable to print.
Physical connections:
AP connected to switchport 11
Switchport 11 configured trunk port native VLAN 100 - allowed vlans ALL
Printer connected to switchport 10 - trunk port native VLAN 900 - allowed vlans ALL
What am I doing wrong? I'd really appreciate any assistance.
Many thanks
