Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
I was wondering if somebody could share their experience with SD-WAN. Has SD-WAN eliminated dropped calls in your network? Please comment on which Cisco SD-WAN solution you are using as well. Thank you for your response in advance.
We have 2 circuits at a branch, internet and MPLS. We understand that call quality may not be as good as the MPLS. However, we would like to know if SD-WAN would eliminate lost calls if the MPLS circuit failed. Would the failure be noticed sub-second, and the voice traffic be re-routed over the internet circuit so that it would not fail?
What if the failure is upstream in the SP and not directly on the link?
